Spin Indexer Slipping
epanzella
Apr 8, 2013
2,040
I have a no name 5C/ER32 spin indexer that loses it's registration between the spindle and the indexing plate when milling anything but a super light cut. Upon disassembly, I was surprised to find that the indexing plate is just held to the spindle by the friction of a threaded ring. No key, no nuffin. No matter how tight I make that ring I still have to tip toe around that indexer like it was made of gingerbread or it slips and ruins the part. Is this the nature of the beast or am I missing something?
Are you talking a spindex or an indexer ? They are 2 different animals .
I'll bet the factory was gluing them and forgot to do it on yours. Just a guess
In any case a key or something should be installed
I have this. It uses 5C and ER32 collets
From the description, it would appear that the index plate should be free to rotate relative to the spindle. Otherwise, why would they include a spanner wrench. I can see the utility of it as it would permit alignment of a prior feature to the index plate. I have a Phase II brand and the collar on mine doesn't budge so it may have been tightened with LocTite used to prevent movement.
From the description, it would appear that the index plate should be free to rotate relative to the spindle. Otherwuse, why would they include a spanner wrench. I can see rhe utility of it as it would permit alignment of a prior feature to the index plate. I have a Phase II brand and the collar on mine doesn't bufge so it may have been tightened with LocTite used to prevent movement.
Problem is I was milling a hex and by the time I got all the way around I had a trapahedarectozoid. I'll try red locktite before getting too ambitious. I don't know about the wheel but the spindle is hard.
That is what is known a s a whirley gig and is not made for milling . That is used on a surface grinder for grinding down short shafts . If you need to mill , you need an indexer such as a Hardinge , Phase 2 etc . They have plates making it impossible to slip .
I suspect that Phase II realized your dilemma and locked plate and nut. I couldn't budge my nut. The manual makes no mention of loosing or tightening the nut and a spanner wasn't included.
I purchased mine for measuring runout on syringes we were making at work. I have an RT mounted in my mill so I haven't used the spin indexer in the fashion that you are.
