So the Workshop model is the latter version...
Edit: so I just searched Steve Wells site and read through the early 1904-1930 SB catalogs he has complied there.
Looks like SB introduced the 9” series lathes sometime after 1914 and prior to 1923. These series of lathes are described in their “Junior Lathe” series catalog No. 44 (circa 1914) and No. 79 (1923). However, in November, 1928, SB introduced a “new model 9” Junior” lathe, (seeCatalog no 23) having fewer features, a new semi steel bed, and a wider apron.
Later, in March, 1931, Catalog No.22-c, SB introduce, for the first time, their newly designed and improved “new model Junior 9” lathe”. This new 9” “Junior lathe” was built from their existing 9” standard change gear components, but with a wider cone pulley, and without the automatic cross feed function, friction clutch, large face plate, center rest, traveler rest, or quick change gear box.
Hence, the “Junior” designation appears early on to refer to their introduction of an entirely new, smaller sized 9” lathe, (Junior to their early smallest 11” lathe). Then in 1928, they introduced a new 9” Junior Lathe design, as a stripped down, production lathe, having less tooling than their fully equipped, standard 9” lathe product line. Apparently, SB refined their marketing approach and model designation as they made incremental improvements in lathe design and expanded their product line.
They also changed specific model numbers in successive Catalogs, as they added features, or changed their design. For example, my 1925 9” Lathe is listed in Catalog No. 79, as model 61-A. “61” referring to a quick Change Gear Box lathe, having “-A”, a 4’ bed length. 7 years latter, Catalog no. 22-c identifies the modified version of this lathe as model number “82-A”.
Matt, thanks for the info on the tail stock. Much better than trying to extract with a bearing puller.
Any tips on disassembling the clutch assembly. The little shaft that holds the star knob seems to be seated pretty tightly into the clutch. I can only unscrew the backing nut a turn or so before everything binds up. Still need to pull the apron off the shaft to get at the backside.
Glenn
