Thanks, the pic in post 5 looks just like mine. So afar as I can tell. Don’t have the apron off the lead screw yet- just got it loose and ajar tonight, and cleaned it up a bit, in situ. Lot of gunk came out just using brake cleaner. The original owner mostly did wood turning with this. But that was between 1925 and 1938, when he passed away and the machine was palaces into storage by the family - from whom I purchased it a few years ago. So has been in storage ever since- so far, lots of dried sawdust, dried machine oil and dust clogging up everything I’ve looked at.
I suspect the clutch is probably cracked with this dried residue. Fortunately old oil and saw dust is a superb preservative.
One big question- looks like the only way to get the apron off the lead screw is to run it out the end of the ways, past the tail stock?? Is this correct?
A second smaller question, the tailstoxk locking level is missing. I ran a 5/16” threaded bolt into the insert, but it did not tighten down the tailstock spindle. So Iam thinking, the spindle locking nut is likely frozen in the tailstock casting. Can this be pulled out with a bearing puller? Or is there some kind of locking spline or cam inside the housing, that has gotten twisted somehow, preventing movement?? Don’t want to break the casting trying to pull against some physical obstruction inside the trailstock.
In answer to Manual MAC, I do not believe this lathe is a Junior. I think it is a standard 1925 9” model 61-A. Don’t have a copy of that specific catalog description in my file, but couple of years ago I found the 61-A catalog on line and it matched the description of the machine. But I do have the original sales receipt, from 1925, and it identifies the lathe as a “9” lathe”.
I am no expert on these early day SB’s, nor their sequence of lathe development, but did see they have had a standard 9” lathe in their line up for nearly all of their early production history, from the early 1920’s maybe even 19 teens through their post war 9” A, B, and C series production. From what I’ve read, the junior was a separate machine design from their early 9” lathes.
Thanks for your assistance so far!
Glenn
