South Bend 9 lathe Clutch issue
Talber8
Mar 25, 2020
11
1948 SouthBend 9b Lathe - developed a clutch engagement issue.
After playing with creating knurls in steel, the clutch for the auto feed stopped working. With the clutch knobbed turned in until tight (3/4 turn) and the selector engaged, the feed is not engaging, and the hand cranks can still be used.
im assuming from the pressure of knurling I may have bent something or flexed a piece out of position.
im assuming the carriage needs to come off but any advice on what I should be looking for? I’ve never taken the carriage off myself.
Can't help with the clutch issue, I have a C.
This is a good reason to make a clamp type knurling tool,though.
I don't think you broke anything, probably the cone clutch needs adjusting/shimming or is worn. Pretty sure you have to remove the carriage to fix
-Mark
Carriage removed, nothing glaring obvious. When I turn the clutch it spins freely, and those half plates move freely. But when I screw it clockwise, it should tighten up and and put pressure on the outside right? They don’t it just free spins689B78F5-086F-40D8-8EDF-8F4F47590E54.jpeg
Something doesn’t look right with half plate on right. Have you took clutch apart.
No. Best I remember unscrew knob on front. Half plates should be loose enough to come out. Check key inside worm for wear while apart
You should be able to see what’s not working. Tighten knob. Plates should lock to gear
I’m not sure what the issue was, but disassemble/reassemble fixed. I wonder if it was bound at the knob, or where the knob shaft comes out. I put a good amount t of force on it while it was on the lathe, enough that I knew it was t right at all. It was dirty but not abysmal. If it were to happen again, I think I would try with apron still on to losen the star knob a little.
when it happened I was knurling with auto feed, and after that was issue.
I don’t know, but learned a few things! Thanks for the inputs.
