One of my most useful workshop 'tools' is a telescopic magnet to save me bending down every time I drop a tool or drill bit etc.
For collecting swarf i made a gadget with a retractable rare earth magnet inside a capped copper water pipe with a generous size grommet a few inches from the end.Also useful, when I put a polly bag over it, for picking up swarf and chips, reverse the bag and shake into the bin.
I also use poly bags with internal magnets as way protectors and do as above.
Not my idea, this or another forum tip.
Magnet works through the copper to grab a handful of swarf, then when over my shop bin, retract the magnet up the tube and the grommet scrapes off all the swarf.
Best thing since sliced bread.
I used surplus carbon fibre tent pole as the inner shaft but wood dowel would do fine or aluminium. Cost me only for the 2 end caps...total of $2.00
The pole, tube, shaft, magnet and a screw to secure a surplus magnet to the shaft were all in junk stock.
You can buy them for about $80.
Sent from my GT-I9505 using Tapatalk
A DRO has two advantages, at least for me:
(1) It saves counting turns. This is especially nice with Chinese tools that have metric leadscrews and pseudo-inch calibrations on the dials, or else 1/16" pitch leadscrews. It's always a challenge to convert an inch measurement to turns in these circumstances. Yes, it can be done. But when I'm machining, I want to use the limited bandwidth of my aging brain to decide on details other than keeping track of turns.
(2) It lets you know where you are (OK ... where the tool is) regardless of backlash. You don't have to keep track of which way you last turned the crank. Think of using an edge finder to find the center of a part, where you have to approach opposite faces from opposite directions. Again, it can be done. But to do a good job, you have to know the amount of backlash to a gnat's eyelash. Very easy to make a mistake.
YMMV
