Right on... Carbide needs a faster SFM than HSS. Also, seems every lathe likes to be handled a little differently -probably because of how rigid it is or if the belts slip etc -so experimenting a bit with feeds/speeds is necessary once you get in the proper ballpark range.
Just the other day, some guys helped me with feeds/speeds with milling cast iron and it was very helpful. Once they got me in the ballpark, I tweaked my way around and finished in a jiffy w/o damage to the endmill.
Heat treating... That's an important topic and it's possible those bucket pins that Vince is working on might indeed need to be heat treated. One thing for sure, if a bucket pin cuts loose, somone can get hurt and at the least, the other pins will get cocked and be a pain to punch out. One thing though, if you don't use the right recipe of temperature, soak times and quenching technique, you'll almost certainly end-up with a weaker piece of metal than what you started-out with.
I'm by no means an expert, but as a rookie, 1045 steel seemed to be easyer to turn with carbide cutters, I have a lead screw, and found that my cheapo craftex 7 x 21 or (19?) worked a lot better with smoother cuts if I turned it pretty fast with a slow feed and the cutter I was using also helped. I usually get it real close and then finish with some emery cloth to really make it shine, if I'm going for super accurate, I test with a dial indicator, seems the more I learn about machining the more fussy I get...lol
I seen a you tube video about a guy that made some really heavy duty pins, and then heat treated them in a wood stove, then cooled them down in water for the temper, keep in mind, use a metal pail if your going to drop any hot steel into water.
