I have four vises and two of them are the screwless type. The largest of these has 3" wide jaws and is the one I use 99% of the time. The larger 4" Kurt-style is so long that it really hangs over the front of my little benchtop mill. It also is taller so it reduces the Z-axis work envelope a bit more.
The screwless one's form factor is just about ideal for my needs, and, once I learned how to quickly tram it, no big deal to remove and re-install. One pass with the DTI, tap into alignment and it's good to go.
One of my first milling projects was to make hold downs for my vise. I only had to make 3 to get two good ones . I keep the failure around as an object lesson: if you pause work on a project, make SURE you really know what the next step needs to be. Don't assume your memory is correct.
