First, you want the angle to be less than 30 degrees, never more. And that angle is measured from the cross slide direction, not from the spindle axis. Sometimes the degree markings on lathes for the compound angle are laid out measuring from the spindle axis at zero to the cross slide at 90 degrees, which will give you a 60 degree angle to the cross slide if you set it at 30 degrees on the dial. Get the compound pointed directly in line with the cross slide. That should be 0 degrees, not 90. Then swing the compound to the left as you count off the degrees until you get to less than 30 degrees. Anywhere around 29 degrees is probably fine, it is not critical unless it is more than 30 degrees which will leave a stair step finish on the right flank of the thread.
