Hi,
Was hoping to get some feedback on why the single point threading I was doing on mild steel stock caused the workpiece to be pried from the chuck on my lathe. This has not happened to me before, but I don't have a ton of experience. Here are the particulars:
While there was only 3/8" depth of the chuck jaws holding the piece, I was surprised that it so easily yanked the piece out of the chuck (which I had checked the tightness on prior to threading). Looking for some advice on what to try to do differently next time.
Thanks.
- Material: 1018 mild steel, 3" round bar
- Chuck: 6" 3 jaw. Given the diameter of the stock, I had to flip the jaws such that the workpiece was only held by 3/8" depth of the jaws.
- Cutting tool: Kennametal carbide single point threading insert. Using a 12TPI insert to make a 1/2-13 thread as they don't make a full profile 13TPI insert and the 12 is all I had.
- Threading passes: Following Kennametals suggested pass count and cut depths. With that said, I did a couple additional spring passes in between increasing depth of cut.
- RPM: 200
- Lathe: Hardinge HLV-H
- Overall length of workpiece: 5"
Thanks.
