- Feb 2, 2014
- 1,185
I was surfing the internet and this drawing showed up and cough my eye.
It is a 1900 Gobron-Brillié opposed-piston engine.
It is a 2 cycle 2 cylinder 4 piston opposed engine.
I have only been able to find 4 drawings of the engine and almost no technical data so a picture is worth...
I will try to build a single cylinder 2 piston 4 cycle opposed piston engine of similar design.
I have already built a 2 crankshaft 2 piston opposed single cylinder chain drive engine that runs just fine. So I have high confidence.
I usually start by building the crankshaft of the model first and then make the engine block fit the crank. I had to order the ball bearings for the crankshaft and I wanted to get started so I drew this up for reference.
I marked out the lines on a previously sized block of aluminum.
Milling out the parts that don't look like an engine.
Milling the connecting rod relief sections.
And the results so far.
Thanks for looking
Ray
Thanks for looking
Ray
