Simple feed rate chart.
The thread & feed chart on my Nardini is about knee-high. At my age, I hate bending down or squatting. I made the charts in Excel and printed them on letter size sheets. I keep them in a binder on a shelf next to the lathe.
My MIG welding machine (Lincoln MigPak-180) has a great chart for work thickness, wire size, shield gas (as inputs) and wire feed speed and voltage (as outputs). The PITA is that the chart is inside a flip-up side cover. I keep the machine on the lower shelf of the the welding bench, wedged in beside the stick, TIG and plasma cutter machines. When I need to open the side cover to check the cart or change spools, I need to put a milk crate on the floor and then pull the MIG machine out onto it.
I've done two things to help:
1) I put a tag with the installed wire size onto the machine handle, so I can see at a glance what is installed, and
2) I took a photo of that chart, and then printed and laminated it and have it stuck with a magnet to my bolt cabinet.
No more crawling on the floor to find the settings.
Brian
Brian
Brian, I went one step further, and printed the chart on a magnetic sheet and just cut to size and stick it to the welder. Just make sure you get the sheet that match your printer, Laser or Inkjet, they are different.
Miller offers a wonderful set of slide rules for welder settings. I've seen a few for tapping, but I'd love to find some good machining slide rules for surface speed and feeds, etc... anyone got such a thing?
Actually I have fairly well stabilized on around 4 thou per revolution. Seems to work well over a large range of materials, speeds and inserts.
No doubt it's not optimal, but it's easy.
Me, too: too much trouble doing manual gear changes on a Mini-Lathe!
Ive seen this on so many small machines I actually thought it was standardized. :dunno:
Hold on, let me dig one out..... there was a post here years ago about a free one I'll find the company and the link...
Brian
