- Nov 5, 2016
- 1,420
You most likely know this, but there are different types of silver solder. I don't think the soft silver solder i.e. Harris StayBrite (silver bearing solder) will work for this. I would use hard silver solder. I don't braze my blades because I have a blade welder, but this is the hard silver solder I use:
I use it with both the white and higher heat black flux. They both work fine depending on the application.
Very strong!
Ted
Harris Safety-Silv 56% 1/16 Silver Solder Brazing Alloy 1 Troy Ounce, 75310 5631 - - Amazon.com
www.amazon.com
Very strong!
Ted
