- Mar 19, 2014
- 2,671
This is something I did a while ago, but this site has not seen it. This is a welding and also wood project I did. All the metal and wood work for the stairs took me 6 months from start to finish. Not pictured is another 50 feet or so of railing. The railing is bent up metal, a little hammering, some store bought ornamental elements and then it’s all wire welded together. The curves in the wooden hand railing are strips of glued together white oak. The curves where glued in fixtures in place on the steps of the stairs. Used a slow dry glue and wire ties for the clamps. I tried regular clamps but the wire ties worked better. It took three tries to get that ~260° turn done right. And all the sections of hand railing are finger joint assembled together. There are no simple wood butt joints in this picture or anywhere in the house. I like to see the natural grain of the wood, so no paint anywhere. And because of the clear finish on all the wood, its joints must be as tight as possible (can’t use a filler). So, no simple butt joints and no cross nailing anywhere, they must be tight and strong. I did the hard wood floors with feature strip and all of the molding in the house too. Even made the form cutters for the moldings from tool steel.
