Show us your old iron!
Another One
K & T Milwaukee Vertical Mill build February 1942, This and the Jones & Shipman Surface were free and they were plug & Play.
Paul
Here is our old Barnes lathe. 18" swing circa 1918. We stripped it down once and replaced the headstock bushings as well as the apron bushings. There is a splined knob that pulls in and out to engage the longitudinal feed. Several teeth had been broken off and we had a friend make me a new one. I have added two new chucks and an Aloris quick change to it as well as several live centers. It came with a huge face plate as well as a steady rest which I have used quite a few times. There is a picture of my Studebaker crankshaft in it. The area where the rear seal rode on had been badly pitted so to repair it I used a parting tool and reduced the diameter slightly, about 1/16" and built it up with JBWeld and then brought it back to spec. and finished it with some 400 grit paper wrapped around a square file. As you can see it also got a paint job.
Still use it for jobs too big for my 9A SB.
Nick
Looks a lot like my Model W Monarch, Reds. I should take a picture, but this will have to do for now:
I got this Prentise Bros. treadle lathe, a few years ago. It had been in one family for 4 generations. I bought it from the 4th owner. It is complete with various chuck, steady rest, face plate, change gears and a lot of vintage tooling. I do not intend to restore but hope to clean it up and preserve it some day.
Charlie, how are you coming on the clean up?
The seller built a power unit for it, when he was in high school, back in the 1950's The power unit stands behind the hearstock and bolts to the back of the lathe using 2 of the existing factory holes.
Here is some of the tooling that came with it.
Charlie W.
Charlie, how you coming on clean up?
Here's a little smaller version of a Barnes drill press very similar to yours, Shawn...
Before...
After...
Here's an old Bertram lathe manufactured in Dundas, Ontario...
Before...
After...
Four new gears machined and installed...
Cheers....
Brian
After...
Before...
After...
Cheers....
Brian
Did you find them kept outside? The are truly wonderful looking machines now!
