First added the DROs.
Then came the home made power feed.
Then to make life a little easier for me I added sockets to the two main things I tighten, the vise and draw bar. This way I can use the 3/8" ratchet for both.
View attachment 49516View attachment 49515
Then made spindle lock because kept loosing the handle. Had to put it on an angle because of LED lights I made and added around spindle.
Made hand wheel for x axis after buying one for y.
Made hand wheel for fine feed and realigned so now it turns super easy.
Added air spring conversion and then put z stop on it after the stop on the column for z broke in half...bad casting.
It is a crazy looking stop. I just dop rod in postion and tighten screw.
Added stop blocks on x and then added microswitches to the center stop which causes the power feed to reverse direction.
Shot of the mill.
Ed
Shot of the mill.
Ed
