Should I buy this INDEX SUPER 55 mill?
FWIW, B&S 9 collets are plentiful and very reasonably priced these days. I just bought a full set, new, ground and hardened for $145.00 . little machine shop carris them, as well as several eBay vendors. I wouldn’t worry about B&S availability for this machine.
Regarding whether to buy or pass, I’ve kind of reached the point that if it where me, I would pass. And keep Looking for a decent used machine for not much more - $2500 or less.
In your photos, the machine scrapings show a lot of what looks like localized high production wear in one or two spots. This is usually caused when the shop doesn’t move the set up and fixtures back and forth on the bed to equalize wear. This is very poor technique, suggesting poor maintenance and early,often fatal wear and tear. It’s likely the never been used throughout the full travel of the bed - meaning you might be fighting abnormal bed wear in the usual middle position- forever causing you set up problems.
Also the broken parts and loose travel etc mean you will have to spend considerable time chasing parts or fabricating something from scratch. Overall the machine seems to have had a hard life. I have a theory that indifidual parts don’t wear out on machine tools - rather, all parts wear at the same rate. Some just break earlier than others. Basically the machine wears out everywhere, over time. So several worn, broken, or missing parts, means all the rest of the machine has experienced the significant wear and tear. Something to beware of...
It’s fun to contemplate buying old machines. But I’ve found its more fun to buy one that works, and just go make stuff!Flustered
Glenn
If you like it just offer him a lower amount you feel good about . If he takes it your both happy. I think you enjoy the challenge of doing the tear downs and repairs . Just my take on things. I wouldn't give him $750 tho . Around here there's lots of really nice mills. Under the $2,000 range. I'd offer $500. And just say it's gonna cost plenty to get it up to be a usable mill. Parts aren't growing anywhere for that baby.
Having seen what you can do with those other little horizontals, I think you can do whatever needs done to it. The question I guess is, do you want to?
I would jump on it. But then I do like Index Mills.
UglyDog mentioned that he has some #9 B&S tooling.
One other thing to check is whether the event that broke the table end support bracket also bent the x-feed lead screw.
While not necessarily a deal killer, it's a good thing to know going in.
-brino
