Shop Organization — How I attempt to keep track of stock, supplies, hardware and whatever.
ChazzC
Jan 4, 2021
2,625
Hardware Storage
Organizing & labelling (always helps) my insert screws:
The little boxes that I used for the insert screws were found on Amazon when I was looking for way to organize tiny set screws without taking up too many "cavities" in one of the Plano-style boxes:
in my hardware stack:
Tooling Storage Ideas
Consolidated my US & Metric transfer screws:
Prep'd two storage tubes from 3" PVC drain pipe (the low pressure/density pipe works great for this; plain test caps glued on the base and test caps with tabs for easy removal for the tops:
Keeps these less often used tools (live bullnose center & MT3 3/4" chuck) clean and storing them on end takes up less space:
Metal & Plastic Stock (More Labels!!)
Didn't reorganize, just re-discovering, so I added labels:
I kind of knew what was in each bin/box, but this may make it easier.
Mini-Lathe Chuck Storage
As everyone should know by now, I like things neat & tidy (tickety-boo?). Chuck storage has always been an issue for me – they need to be close at hand, but out of the way, while not taking up space that could better be utilized. At the same, the chucks need to be protected from dust, dirt & swarf. Over the weekend, I came up with a solution that looks like it will work, and here's what I did.
First, I spent some time removing the labels from some plastic "jars" that were wrapped around Kirkland™ Chocolate Covered Almonds (sprayed the labels with Goo-Gone® and let them sit overnight until the labels could be easily peeled off, wiped the jars with 90% Isopropyl Alcohol and gave them a good wash & dry. Then over to the bandsaw:
Not the first time I've used a 2-4-6 block as a guide. The sawing went surprising smoothly, and shortly I was left with two pieces:
The guide did it's job, and the cut was square (and the two ends of the cut met).
After deburring the cut edges by rubbing them against a green Scotch-Brite™ pad on the bench and some detail work with a small strip of 220 grit emery cloth, my covers were done:
As you can see, I didn't waste the lids: the 4" 3-Jaw & 4-Jaw chucks sit back-down in a lid, and the bottom of the jar is a perfect cover. There is also a 3" 3-Jaw chuck back-down in a lid, but with a 16oz Deli-Cup as a cover. Also seen at the far left of the row is my 5" 3-Jaw, sitting in a larger cap with a clear food storage container used as a lid. The chucks are out of the way, but close at hand, and protected against the elements. When I need bench space, I remove two bolts that secure the lathe baseplate to the bench and push it back against the 1x8 that the chucks are sitting on:
leaving clear bench space (with numerous mounting holes for various portable tools):
(My) Typical Tool Organization & Storage
I've mentioned the Really Useful Box® in a number of posts: they are sturdy, come in a wide range of sizes and I find them to be true to their name (Really Useful!). I use them to store both tools and tooling, keeping like things together with necessary tools and (reasonably) organized. Here are some samples:
No, I don't have a deal with Really Useful (maybe I should?); I buy mine at Staples® and other office supply sources (usually local pickup: while the boxes don't weigh a lot, they take up a lot of cubic inches/mm, and that drives the cost of shipping).
More Hardware Storage
I found unused wall space in the "Dry Goods Storage Pantry:"
You know what they say, "Nature Abhors a vacuum."
2 Bolt Depot Racks, 9 Plano Boxes from Amazon (plus a leftover Bolt Depot box), 8 TapCons and I can finally put away the extra hardware I bought when I added DRO's to the Mini-Lathe last October.
Reorganized (or is it organized again?) Hardware Storage
And finally put away the extra/excess hardware from the Mini-Lathe DRO Project I completed Last September!
Stack-Up in the Shop:
Mostly Imperial
Mostly Imperial
Mostly Imperial
Stack-Up in the Pantry (see More Hardware Storage & Updated Floor Plan):
Mostly Metric
Great idea; but unfortunately I standardized on Casio EZ-Labels years ago and it's hard enough finding quality black on white tape in the 18mm width I mostly use
