- Feb 1, 2015
- 10,085
The rest of the story re: heat pumps is their maximum efficiency occurs when the temperature difference between the heat source and the heat sink is near zero. As the temperature difference increases, the efficiency drops rapidly. A heat pump using a geothermal source is the best bet as ground temperature is fairly constant year around. At my location, the temperature is around 54ºF so heating a shop to 65º is still fairly efficient. Properly utilizing ground heat requires some rather sophisticated equipment. One way that it is done is to use a deep well as the source with a closed loop for the refrigerant. There are open loop systems as well but there is a risk of contaminating the ground water. Another way would be to use a large buried tank...............................
I was talking with my HVAC guy in Elk Rapids a few weeks back and he strongly recommends heat pump technology (mini-splits). What he told me was using any kind of fuel to heat air or water gives a max of ~97% efficiency, where heat pumps can hit ~300%.
John
Simple electrical resistance heating is 100% efficient. The problem is that it is relatively expensive and best used in low demand situations like mild climates or low use areas. My attic workshop has both a mini split heat pump and baseboard resistance heating. The workshop is normally isolated from the rest of the house and isn't heated unless in use. The space has the chimney from our wood furnace running through the center and this will keep the space at around 55 - 60º when unoccupied. I use the resistance heating to bump the temperature up to 65 or 70º when I want to work up there. If the outside temperature is above freezing, I will use the heat pump to maintain the working temperature; otherwise. I use the baseboard heating.
