I have a 4400 lathe that I bought in 2008 and it had the same misalignment problem as shown in the image in the first post. Being as I was used to working to tolerances as close as +/- .0002 as a tool and die maker, this was totally unacceptable. I thought about modifying the tail stock by using the method shown on YouTube by a guy from Brazil named Luiz Ally. He has a five part series on how to deal with the tail stock problem. I ended up with a tail stock that can be dialed in with a lot of fussing around, but the effort was worth it. Basically, I had my tail stock split in two on a wire EDM machine so I was able to use a combination of clamping screws and shims to get it right. What I did is probably not the best answer to this problem, but it worked for me. Here are some images that I hope will make this a little clearer. The first one shows a pattern of six holes drilled through the tail stock. They are #21 all the way through at this point to allow for tapping 10-32 and clearance drilling as needed. Disregard the two odd holes, as they were not needed when this was all sorted out. These six holes were drilled through at this time to ensure alignment when the two halves of the tail stock were mated up again.
This next image shows the results of the wire EDM process. Finish the clearance drilling and tapping of the 10-32 holes at this point. I had to have the clamp screws enter from opposite sides, as I didn't allow enough room between the top and bottom rows for the screw heads to clear each other. So much for all that tool and die work. Missed something very basic.
When the two halves are ready to be mated again, an alignment rod must be prepared. Start with a 3-1/2" length of 5/8" or 3/4" diameter aluminum rod and make a skin cut 2-1/2" long. Check for any taper in the cut and adjust the head stock as needed. This method is recommended by Sherline to align the head stock. If using 5/8" diameter rod, be sure to take very light cuts, as the final diameter needed is .6188 to match the diameter of the tail stock ram. When the rod is the correct diameter with no taper, the two halves of the tail stock can be set up for the mating and aligning to begin.
Next, you can see the two halves mated up and the clamping screws installed. Now for the fun part. Working with feeler gauges, you need to determine how much shim stock to insert into the gap left from the EDM process and adjust the relative positions of the two halves so the assembly will easily slide on and off the alignment rod. Be sure to have the tail stock gib snug, but not tight on the bed ways. You need to be able move the tail stock along the bed ways, but you also want to minimize any twisting motion. When mine was all done, I ended up with .002 more shim at the dial end of the tail stock than the chuck end. That doesn't seem like much, but when you think about how far out a drill chuck extends and an inch or two more for the drill, that taper over two inches becomes quite a bit more at the point of a drill when you need a hole centered on a work piece.
If you choose to watch the YouTube videos by Luiz Ally, you can see that his method is easier to accomplish than this one when the final alignment is being done. But, I've always done things the more difficult way. A real problem of mine.
Here is a copy of the web address of the video.
Sorry, but I don't know how to make the address clickable. You will need to copy and paste to get to the first of five and go from there.
Well all right then. A moderator or someone who knows how to install a hot link to the video has taken care this. Thanks.
