- Jan 24, 2015
- 239
Dear All,
I have a Sherline 4400 Lathe, purchased new back in February. In doing some work between centers on a very thin piece, I discovered that my tailstock appears to be misaligned. The misalignment is enough to taper a 2" piece 6 thou. I did some tests, and this 6 thou taper over 2" occurs when using 3/8" stock as well. The tapering is uneven, and there is a ton of chatter when cutting near the tailstock, diminishing as you move towards the spindle.
My spindle is aligned perpendicular with the lathe axis. A 4" long brass 1/2" diameter rod will have .0005 TIR when machined using only a chuck (not between centers).
I took a photo of the tailstock with a live center against the spindle with a dead center.
The misalignment also helps explain why I keep getting slightly off-center holes when I drill on the lathe. I thought it was my technique.
My question is how much misalignment should I expect. Is this pretty standard for Sherline? If so, I am surprised, because all of their other features seem very precise for a machine of this price.
Sherline offers adjustable tailstock holders. Given this degree of misalignment, I am going to have to buy all of them. This will make the lathe much less fun to operate, as I will have to do the alignment each time I switch between centers and drills.
Thank you for your help.
Cheers,
Tom
Cheers,
Tom
