Hey dalee,
Well got some info on the lathe. Here it is..
[attachimg=1]
Sherline lathe setup:
Basic operating coordinates for a lathe are shown above.
The X movement moves the cross slide in and out. The commanded position is in diameter.
Moving to X=1,
G1 X1 F10
Will place the tool tip at a position that will cut a 1" diameter part. This is 1/2 inch from the centerline of the spindle rotation.
The Z coordinates control the saddle movement left and right. Set the Z=0 position at the front of your part. All plus movement is away from the part, and all minus movement is inside the Z area of the part.
Setting tools:
In the picture above the part in the chuck is .5 inch diameter. If the tool is jogged until it just touches the OD of the part, it will be at 1/2 inch ( .500). To do this without breaking the tool. or marring the part, place a slip of paper between the part and the tool tip. Jog in toward the part until the paper is squeezed between the two and won't move. If you use the incremental jog set to .001 inch, the paper will be held at a very repeatable position.
In DeskCNC, once the tool tip is in position in X, from the menu select Controller-Set Coordinates, and enter the diameter of the part ( .500) in the X box and click the Set button.
Click Exit to close the Set Coordinates dialog.
Now jog over to the front of the part, and again jog in small increments until a piece of paper is held between the tool tip and the front of the part.
From the DeskCNC Controlelr menu select Controller-Set Coordinates, and enter 0 for the Z value. You can also click the Z-Zero button above the digital readout area to zero the Z value.
Any jogging from this point on will display the machine position that will be cut on the part. you can manually jog the tool tip and face the part, or turn a diameter.
In Vector Cad-Cam, the Desklathe post processor will provide a translation of lines and arcs drawn in Vector into the G-code required to cut whatever part is drawn in Vector into the commands to make the part in DeskCNC. These command are G-codes.
