4
4GSR
Forum Guest
Register Today
The gearing in the headstock looks nice. Be sure to put some fresh oil in the headstock. My preference is ISO 46 hydraulic oil. Do not put gear oil in the headstock! The gearing on the outside of the headstock that feeds into the QCGB is in decent shape. Unless you just want to take it apart I would leave it alone. Saturact in ISO 46 oil and let it run. If you decide to remove the gearing, make you a skecth on paper the arrangement of the gears so you will know how it goes back together. Just start with the outer most one and remove, then remove the next gear and so on until you have them all removed. They are not press fit on the studs, should slip right off without any effort.
I'm real surprised to see a Sheldon name on the lathe. I highly doubt there were many sold of this design under Sheldon. Probably used up the stock on hand until the new Sheldon-Sebastian lathe took it's place in the early to mid 1950's. Now we know another piece of the pie of it's existance under Sheldon. Ken
