- Jan 28, 2015
- 36
Hi, I don't post here often. I have posted about my Comet Bport Taiwanese copy.
I have had this lathe for 20 years in storage. It was long past time to get it in to my shop and working again. It was inherited from my grandfather. It says Sheldon Sebastion, have not had a chance to clean the info plates or find the serial numbers. It appears to be in quite good shape except for the surface rust. Came with a 3 and 4 jaw chuck, steady rest, faceplate, taper attachment and few odds and ends. It is now in my shop after quite a bit of rearranging. (no pics yet). It does not have the original motor and I have not dug in to it to determine if it is single or three phase. I can run it either way since I built a converter for the three phase mill. It is a heavy beast for sure! I was hoping for a smaller lathe but I already have this and I do have projects I can use it for. I will post more info as I clean it up. Any info from members here would be appreciated. Hope this is the right place for this.
Glen
Glen
