Interesting about that point. Right now I'm looking at cutting .050" aluminum sheet, and was thinking that a thinner kerf would get through with less resistance, letting it run cooler and lose less material. Do you think the thicker kerf would be important for material like that, or did that apply to thicker workpieces such as rod, tubing etc?
I wouldn't worry about it Frank. The stiff blade will go through it like melted butter. The only times I've seen anything get hot is when cutting 1/4" or greater.
