I have a Harbor Freight 30" 3-in-one sheet metal machine. Also have a Tennsmith 37" stomp shear and a Diacro 24" box & pan brake. Bought the HF machine first. If I'd have bought the Tennsmith shear and Diacro brale first, I wouldn't own the HF machine if that tells you anything.
The HF's work fine for what it is, but you'd be really hard pressed to shear 0.100" aluminum. Kudo's on one hand to HF; I broke one of the cast link arms that goes from the eccentric at the crank handle/slip roll down to the shear bar trying to bend a 12" length of 16-gauge steel (think they're rated at 20-gauge max). Called HF and got a replacement casting for around $12 back in the day.
My Tennsmith maxes at 0.0625" for mild steel and 0.100" for aluminum. I've cut 12" lengths of 0.050" 303 stainless and 1/8" aluminum around 20" long with little problem. If the HF is rated for 20-gauge (think that's around 0.036" in steel), you're probably at around 0.050" max in aluminum.
On one hand, you might be able to push the shearing a little more than the braking. When you shear on a 3-in-one machine, the link (one that I broke) between the eccentric at the crank and the shear bar/brake "V" is in compression. Can take a ton of load. When you brake, the link from the top to the shear bar/brake "V" is in tension. There's a pair of these links on the sides of the machine, they're shaped like a comma. The bottom of the comma has a bolt that runs through it to the shear bar/brake bar. When braking, this joint is in tension and in my case I snapped the bottom of the casting off. Also, the 3-in-one is hand operated, the stomp shear is my body weight. You can only pull/push so hard with one hand, get a lot more impulse from a hop on the Tennsmith shear.
Another "nuance" with the HF is a lack of table size as designed. Guys have a work-around here. The support table for the shear is about 3 or 4" wide. It can be a challenge to set a 20" deep piece of sheet metal in place, get it aligned with the blade, and not have it move on you. Guys have extension tables to overcome this. My Tennsmith has a 14" table in front of the shear bar. One hand is ALWAYS tied to the 3-in-one machine to turn the crank. You have one free hand to hold the material in place. Always two hands free with a stomp shear.
The press brake is a challenge also. Imagine a "V" block 30" long and resting a 24" wide by 24" deep piece of sheet metal on top. While balancing the piece of sheet metal, rotate the crank to bring the press blade just down to the work, then double-check alignment before bending. Same work-around here, make an auxiliary table to support the work. Also, only one hand available to stabilize the work as the other is turning the crank.
I bought my HF 3-in-one for $500 in around 1991 (going price back then). Bought the Tennsmith shear used for $700, Diacro brake for $400. Think those two run around $2000 and $4000 new; another case of you get what you pay for and should expect more for over 10X the cost.
If you are only going to do an occasional job, might not be worth buying the equipment (did I actually type DO NOT BUY A TOOL?!?!). I've had metal cut at a local duct work shop and they didn't charge me anything. Albeit, I buy my 20 and 24 gauge sheet metal from them.
Depending on your length of cut, you may consider an 8" bench shear. They are under $150 and could easily cut 0.100" aluminum. Mine is from Woodward Fab (Chinese generic) and is rated at 3/16" steel. I cut 1/8" steel all of the time. They work like a guillotine shear for paper with no stop fence. Let's you make a cut, advance, and cut again. Maybe more like a pair of scissors where one of the blades is fixed to a base and a long handle on the other one. I've comfortably cut a 15" length of 1/8" steel and held a line well within 0.015" inch.
Bruce
Bruce
