- Nov 21, 2010
- 1,600
Have to aggree with Ron. You will get it, if it helps I use plain ole red majic marker for a rough guide.
Try to hold the angle you want on the horizon (level) moving back and forth against better judgement
I do use a tool holder some blanks are too small to hold on to, cooling every few passes. Just remember
you need to know your toolholder, some -0- back rake and ones with built in back rake. As far as
facets, I dont want to get you in the grinder business, but although I have three, one is hands off with
a fine and finer wheels. Typically my big lathe uses 1/2 HSS blanks, those I will vise up and rough out
with a 4" angle grinder to save my grinder wheels then to the fine stone. Did anyone see the Utube
vid of a 1/2 drill bit stuck in a shaper doing its work. When stuck I have even ground allen wrenches
for 60* threading. See, no rules, not written in stone. Can be done precise with a tool post grinder which
I avoid.
I avoid.
