- Jun 15, 2017
- 581
The plug goes into the cylinder at an angle, so I can't use the plug hole. It can't have any screws through the base because the cutting tool has to cut the base. The web says the bore is chromed on this model.
I believe some people are using friction to hold these, pushing a straight mandrel in so it touches the top of the inside of the cylinder and then putting something like a nut on top of the cylinder to hold a live center.
Locating the nut would be a pain. Maybe a flat attachment on the center would make it unnecessary.
GENUINE ECHO CYLINDER FITS CS-501P CS-4910 A130002280
GENUINE ECHO PARTS Part A130002280 (CYLINDER) Where Used: · 492 S/N: C83615001001 - C83615999999-->ENGINE · CS-4910 S/N: C83515001001 - C83515999999-->Engine · CS-501P S/N: C36712001001 - C36712999999-->Engine · CS-501P S/N: C36813001001 - C36813999999-->Engine · CS-501P S/N: C68515001001 -...
www.sawsalvage.co
