The control panel is nearly complete. I did it to myself again and didn't allow enough room on the panel so everything is a bit tight.
I was running the machine with the panel sitting on the bench with the servo cables strung across the floor and only the breakers and computer for control. It runs that way but I think maybe the customer would like something a bit more normal
The safety systems are now in place, so the panel gets stuffed into the enclosure in the morning.
The stray wiring will be neatly rerouted and neatly tucked away before it goes into the enclosure.
I really hated to run the wiring down the outside of the guard, but there is no other practical way of doing it. Doing it like this and mounting the monitor and controls on the guard has the advantage of insuring that the guards stay on the machine.
When you have cables with big fixed ends on them, you need a way to pass the cable into the enclosure, they won't fit through any normal flex conduit, and I wasn't about to hang 2 inch flex on the side of this thing. So build some pass throughs. These capture and insulate the cables. I made these out of UHMW because I didn't have any Delrin on the shelf.
There is a set of these for each side of the enclosure, the control and computer cabling enters on the left side, and the servo cabling enters on the right side, near the drives.
I'll be test running this tomorrow so I'll get some video of it running.
