- Feb 8, 2014
- 11,187
Today was build a crossmember day (see post above) This is a piece of A36 steel, 6x12x3/4. It needs to get trimmed down to 5.4625 x 11.5 x whatever makes it flat after facing.
So the first operation is to put it in the vice and face both sides to remove the mill scale and flatten it out, most flat bar has some bow in it. It finished at 0.714. I didn't get any pictures of that operation, but you know what a carbide insert face mill looks like
Then anchor to the fixture plate and rough cut the OD. Had this been wider than the vice I would have bolted it to the table with the aluminum under. Then the finishing pass on the OD, this pass is taking of the last 0.0005 per side to finish. This is called doing surface grinder work on a mill ( I have two surface grinders, but neither of them are set up). This again is one of those dimensions that you need to sneak up on, it must be on size. Nice sharp 3/8 solid carbide end mill, ~140 SFM (1420 RPM), 6 IPM feed. It came out on size .
This was bolted down to a 1/2 scrap aluminum piece that was used for a fixture for another project, this allowed working around the entire perimeter.
The next step is to machine clearance for the ram since this will cover the entire front of the press. 0.150 deep x 6 inches. The bottom 1/4 inch of this poor old roughing end mill has just about had it. Wasn't sure it was going to finish this cut.
But the rest of the end mill is nice and sharp so drop it way down through the hole to cut the bolt head clearance.
And the top view
And last, I need to cover the bolt head clearance hole because this just created a pinch point, so screw a scrap piece of 3/8 lexan down to the pre-tapped holes and profile the OD. Access to the bolt is required for machine maintenance. This cover actually installs on the other side.
Tomorrow the crossmember will be installed on the press, 12 hours is enough for today
And the top view
