- Sep 1, 2023
- 1,211
So, now I have a reasonably capable belt sander (shown here: Post in thread 'What Did You Buy Today?' https://www.hobby-machinist.com/threads/what-did-you-buy-today.55645/post-1184362 ), I need to get more knowledge into my head about what belts I should buy.
I have a reasonably decent 6" bench grinder with a couple of Norton wheels on it (white aluminium oxide, one 60 grit and one 80 grit) but like most of us, I've enjoyed Mikey's epic thread on grinding HSS (may he be enjoying a blissful peace wherever he is right now ) and noted his preference for belt sanders.
So let's say I want to use this belt sander for HSS lathe tool grinding. Be good if I could also use it for general ferrous metal tidying and rough small radiusing too. Changing belts shouldn't be too onerous a task on this thing, so having different grit belts is what I have in mind.
So what kind of abrasive material should I be looking out for as regards belts?
Also, are there abrasive materials that are meant for non-ferrous metals (aluminium, bronze, brass, copper, etc.) and plastics (acetal, nylon, etc.)?
Bonus points for telling me about less well known abrasive materials that may add extra capabilities to the sander that I haven't thought of.
As I said, I'd probably buy a few different grits of whatever belts I find myself using, any thoughts on the interaction of grit and material would be welcomed too.
Thank you all in advance for any help.
