- Jun 19, 2017
- 83
Good morning,
I have a chance to add some #6 SAE o ring boss ports to some cast iron valve parts. (#6 has 9/16 UN threads)
I bought a forming tool to get the port profile. The tool is steel but has carbide cutting edges.
My problem is chatter.
I don't have a knee mill. It's a PM 940 V-PDF. (it's not as rigid as a BP type mill)
I have tried various speeds from 1000 down to about 200. Slow seems better than fast.
I tried "free handing" the down feed. That was a disaster. It always chatters.
My best results come when using the power feed set to .10 mm/rev. ( it's finest setting) at about 300 rpm, and stop as soon as it makes a visible counterbore.
doing it like that results in several good ports and then one will chatter. I can't have that happening on customer's material.
I've tried cutting dry, cutting with tapping fluid and cutting with ISO 68 way oil. The -68 oil seems to be the best so far.
I'm considering buying a solid HHS tool with no carbide and trying that, but they are very expensive to buy just to experiment.
What do you think?
thx,
Jim
What do you think?
thx,
Jim
