- Dec 28, 2015
- 115
If I could figure out how to put my gear in in the "signature" of the posts I would have/should have done it by now but .... have not yet figured it out. Am running all Hobart: AC/DC Stickmate, Ironman MIG, and Hobart 165 TIG rigs so I can do AC or DC ... just depends on what I am poking at ... Also have plasma cutter, oxy/acelylene torch, and other small hobby shop stuff: old Hardinge TL lathe, Aceria F2 mill, horizontal bandsaw, chopsaw, grinders and other odds and ends. Trying to set up a shop during a move has proven to be one heck of a challenge - house comes first (according to She Who Must Be Obeyed) - and the shop gets attention whenever I can sneak in some time.
Thanks for your thoughts .... and it looks like you learned some of the same way I did ... burned a lot of that old P5 rod about as big as your bird finger on pipe in my early 20's
Take care and thanks again!
Well now that you mention the mig, sounds like you just need to put them rods in a airtight tube and dust them occasionally. Unless you like stick welding, my rule is anything over 1/4" that needs to be strong and I will use a stick every time. My friend that runs a weld shop tells me I'm crazy and I don't know how to properly set my mig for thick metal, he's right but I also know if I use the old stinkin Lincoln tombstone it's gonna outlast me.
Never used p5 rod? I do have some 7018 big as your thumb takes everything my welder has on DC to run it and it wouldn't mind another 50 amps
