- Jul 25, 2012
- 80
Moved to the PNW from the CA desert, and I had forgotten about welding rod absorbing moisture until I was starting to set up my welding table. I grew up in MO/IA and on the farm we used to store rod in old refrig with lightbulb inside ... not sure if that is "normal" or not, or if we just convinced ourselves it worked ... anybody have any better ideas about rod storage in high humidity environments? Rod ovens are expensive and are not really for storage as much as trying to dry out/salvage rod ....I just need to store small qualities of rod between uses .... right now it is 48 degrees outside and 95% humidity ... go figger.
Thoughts? I appreciate any experience you might have! Take care and thanks in advance. ddj
