The table is the last big part of this build. I had previously filled 3 or 4 drill holes and now scrapped the surface. The table had a high spot or hill right in the middle, as indicated by a surface plate spinning at its center. The scrapping required to flatten, also allowed the removal of much surface damage. The only things left to do is rebuild a cast iron x axis wheel and build a z knee crank.
Oh, and I recently saw a quill quick lever handle return mechanism that I will try and detail.
I hope to compare and contrast this Rockwell knee mill with my square column bench gear head mill as to workpiece size capabilities and other features. I like the concept of a stationary spindle head with movable knee as the work space stays basically the same regardless of size. The bench mill head movements result in sitting down for short workpieces and standing for taller workpieces.
And I've gotten used to the 9" by 32" table of the bench mill versus the smaller 6x24" Rockwell table meaning the work envelope is larger. Has that size 21-100 table been a problem for other Rockwell users as far as heavier machining?
