I purchased the Hemingway Sensitive Knurler kit about three weeks ago. Thought I’d write a review, since there were many things that I liked and several that I did not.
The shipping to the USA was a bit expensive, but exceedingly fast. I ordered on the 16th of July and it was delivered on the 20th.
In the kit, you get some nice drawings and metal stock. Rectangular pieces and rounds that are cut to the required length plus an inch or so.
Pluses:
Pluses:
- I’ve learned a lot about making parts. And about messing up a few of them.
- I’ve acquired quite a few new tools (slitting saw, boring head, collet blocks)
- It seems like a good design. I just finished the last hard/new operation and expect to be done soon. I may have to remake a few parts to make everything work to spec. But I know how to make them now, so it won’t be a problem.
- I found the kit to be much harder than I expected. Some may consider this to be a plus.
- Many of the raw stock dimensions are a tiny bit undersized. I found it hard to tell if this was going to be a problem (see minus # 3 below).
- There are no instructions included to tell you how to make the parts. For someone relatively new to machining, a bit more information would be useful. However, some may consider that figuring out how to do the operations is good; i.e., a useful/positive exercise. In the absence of detailed instructions, there are several well-done videos available on YouTube (search on Hemingway Sensitive Knurler + Youtube)
- There are no tolerances provided on the drawings. Coupled with undersized raw stock, I found this to be a major aggravation. Should I shrink the hole because the pin is smaller than the nominal diameter (there’s also no guidance as to whether you should be aiming for a slip fit or a press fit)? Should a shoulder be exactly the right distance away from one edge on a part that’s a few thousandths short of the stated width or does the shortfall get taken from the other side? Or maybe, I should bring both edges in by half the shortfall?
I worked for a short time as a drafting/machinist apprentice in the late 70s. It was a long time ago, but I clearly remember that every dimension had a tolerance. Most of the dimensions on the drawing had an upper limit printed above a lower limit. Anywhere in the range was acceptable. Some of the measurements were addressed by notes on the page providing a “default” tolerance. But, if there was no tolerance that could be ascertained for each and every measurement, the drawing was wrong. The part would be considered un-machinable and would be returned to the draftsman. - The kit drawings often show metric and imperial measurements. But they often aren’t exactly the same measurement (e.g., 3/8” vs. 9.5mm). That’s pretty close (10/1000ths off), but it’s not always obvious that it’s close enough.
- The kit mixes measurement systems. There are threads specified in metric. And in imperial, And in BSF.
- There’s no upfront guidance available on the Hemingway site about the tooling you need to make the parts. I should have been more diligent and found the YouTube videos before ordering and that would have told me that I probably needed a lot of tooling that I didn’t have:
- A square collet block
- A boring head
- A rotary table ( made do w/o this)
- Slitting blades and arbor
