- Feb 1, 2018
- 1,867
Jeff I use the 5 block or 10 block method all the time and also check the top with a straight-edge/ You can use the straight edge I gave you. You can put in 4 or 5 .001" shim stocks under the SE and try pulling them out. Or just blue it up and set on the chuck and hinge it. Your machine and grinding looks super!
