Restoring a Deckel S0 tool & cutter grinder
And here’s the finished article. Everything back in place, light wired up, new wheel mounted. Very happy with how it’s all turned out.
I went with a smaller push button for the lamp switch, and located it on the top of the electrical box.
I have one 12mm collet, and then what I assume is a mix of imperial. Only the 3/8” one still has a readable size marked on it, so I’ll measure the others and try to engrave the size back in at some point.
But there you go. From a rusty hunk of cast iron and steel to working grinder. :)
