- Mar 20, 2014
- 418
Another busy day. Hubble bubble...
The nitromors does an ok job, if you follow the instructions to the letter. The small stuff cleaned up well, apart from the remnants of some red oxide primer (I think) and some stubborn filler on the wheel guard.
The main body was a different matter. This was it after one treatment with the stripper:
There was a lot of stubborn paint left behind. I think mainly due to me leaving the stuff on too long and letting it dry out. That’s what comes from being interrupted by SHMBO.
A second dose did for most of the residual stuff.
Anything else will be dealt with by some emery cloth. As you can see, stuff I’d done earlier was already starting to flash rust.
So I dunked all the smaller pieces back in the evaporust to protect them. I’ll try and put the motor base plate (the square piece) and the wheel guard in it tommorow when I fish the small bits out. The main casting will just have to go rusty with dignity until I get round to painting it. Which might be after some filler... I don’t know. I’m not that bothered about the foundry marks in the casting - what do you guys think?
I also managed to get the pulley cleaned up and mounted on the new motor. The new motor shaft was only 1mm bigger than the bore, so it was an easy job to enlarge it to 10.5mm and ream to 11mm.
