@mikey just wanted to come back to carbide v. HSS. I'm not using any carbide on the lathe at the moment. The references I've got say that 300-400 sfm is appropriate for carbide tooling with most steel. Compared to 100-150 sfm with HSS.
Given that I plan to mostly work with small work pieces, I'd need to be running my lathe at or near it's maximum 3,000 RPM (5/8" cutting diameter or less).
Then the issue of depth of cut. I've read repeatedly that
carbide 'needs' a greater depth of cut than HSS.
I believe this is to achieve a decent surface finish but, as I said, I have no personal experience with carbide tooling. If carbide really needs that greater DOC, then that means more strain on the (Zamak) gear-train on my little lathe.
Do carbide insert bits for boring perform differently from carbide insert bits for turning and facing?
I'm just trying to reconcile what I thought I "knew" about carbide v. HSS cutters on a little machine.
Craig
Yeah, carbide needs to run at the proper speeds to cut
as intended when turning. You can run slower and it will work but it won't be optimal. As you noted, you will be running at high speeds on small work pieces when using carbide - can't be helped. Give carbide a try, though, because there are times when it is the right tool for the job.
Carbide does not require honking deep cuts to work well and your little lathe can handle it. I don't know where this idea of having to take deep cuts comes from; it certainly isn't based in reality. When we talk about DOC and inserts, we need to keep the nose radius firmly in mind. The larger the nose radius, the deeper we need to go to get the insert to cut accurately. As noted in the boring primer, there is a minimum DOC that an insert can take with accuracy. So, the answer to your question is that carbide needs to only go deep enough to engage and stabilize the nose radius in order to cut accurately. As long as your DOC exceeds the nose radius by about 0.005 - 0.010" or more the insert will cut fine. How much deeper you can go depends on the power and rigidity of the lathe.
The key hassle with carbide is that it requires a minimum depth of cut based on the nose radius to take an
accurate finishing cut. This minimum is usually around 1/2NR. Go shallower and the insert will skate; go deeper but less than the NR and the insert loses accuracy or may chatter. You have to determine the minimum depth of cut your nose radius allows and
plan your cuts so you can dial it in to finish. It can be a royal PITA to find yourself 0.001" away from final size and you can't cut it with an insert.
The
performance difference between carbide inserts for turning/facing and boring is not actually about the inserts, which may in fact be identical.
The real difference is in the process, the tools and in how the forces are encountered and distributed.
When turning, axial forces hit the bar laterally. Tangential forces push down and radial forces push out but here, radial forces cause the
part to deflect away from the cutter. In contrast, when boring, radial forces move the
bar away from the wall of the bore. A part being turned requires tailstock support if it is 1.5-2 times the work diameter to counter this deflection, whereas this is not an issue with boring because the axial forces are down the center of the part and radial forces move the bar and not the part. This is why we can usually bore a deep hole with a long piece sticking out of the chuck and not have it go flying out of the chuck. Okay, so this is the general differences between turning and boring - the forces are the same but the direction of those forces differs, and the impact of these forces on the tool greatly differs. This is one of the reasons why turning on the outside is NOT the same as boring on the inside.
Now, considering the direction of the forces with these two processes and the way the insert encounters the work, you can see that the major difference between turning and boring is that the cutting is handled by different edges on the insert. With turning, most of the cutting is done by the side cutting edge and nose radius, while with boring most of the cutting is done by the end cutting edge and nose radius. Since most inserts have identical surface topography on both side and end (this does not apply to an insert with a flat top and positive axial rake), there is little difference in how the insert actually cuts. However, the geometry of the tool holder does make a difference in performance and you really cannot compare the geometry of a boring and turning tool. Bottom line here is that while the insert may be the same, the performance of a turning or boring tool may differ depending on the tool's geometry.
Aside from geometry, there is also a huge difference in how the tool itself is able to handle cutting loads. Because a turning tool is much more rigid, and given that we can use a live center to offset tool deflection, we can take much deeper cuts with a turning tool/insert. With a boring tool, we cannot handle really deep cuts because the bar is unsupported throughout its exposed length; all we really have is extension, bar diameter and bar composition to handle these forces. So, again, in terms of differences in performance, it isn't so much the insert that differs. It is more about the geometry of the tools as well as the rigidity of the tools and how the forces impact on them. A turning tool can take much heavier cuts as compared to a boring tool.
This is also a good place to tell you that whether we are boring or turning, if we take repeated cuts with the same cutting conditions using a carbide insert then we can expect the tool to produce the same results. This applies to both roughing and finishing cuts. This repeatability is important so that we can plan our cuts.
ANY change in ANY of your cutting conditions (DOC, speed or feed) will produce a change in the repeatability of the cut.
So, Craig, you can certainly use inserts to turn on your Atlas lathe. You do not have the speed, power or rigidity to take big cuts with carbide but these tools will work okay if you keep your depths of cut in a range that produces cutting forces your lathe can handle. It is likely that these tools will not finish as fine as they would on a faster lathe, and you won't be able to hog off huge cuts like the big boys but that doesn't mean you can't use these tools. On the other hand, HSS has some distinct advantages on a lighter lathe that may make it a better choice for turning.
For boring, I recommend using carbide insert tooling for its repeatability.
I hope this helps.
EDIT: I know we're talking in broad terms here and not about a specific insert but I wanted to add that in order to get the chip breaker to work properly you may need to take a deeper depth of cut. On my CCMT inserts, this cut is roughly 0.020" DOC and this will vary with the insert you end up using but heck, even my Sherline lathe can handle that depth of cut. Some chip breakers need more, some less and the insert maker will give you recommended cutting conditions. You, as the operator, have to mess with those cutting conditions to optimize the results you see at the lathe. I mention all of this because there is a whole lot more to using inserts than we're covering here. I also wanted point out that a small lathe has limitations that may limit how useful carbide will be with some materials.
I have used carbide for many years on my Sherline and Emco lathes and they work well for me but they are not my primary tooling. I much prefer HSS on both lathes for most work because I can make a HSS tool do pretty much whatever I need it to do for the kind of work that I do in my shop. Your results will vary.
