Ok, so I have an extra headstock that has had its babbitt removed, the fellow that owned it previously machined what appears to be bronze 2 piece bushings to sit in their place. It didn't work all that well from the looks of the scoring on them. So I'm toying with the idea of restoring the headstock with new babbitt bearings. Now I've seen quite a bit on youtube, and Keith Fenner has a couple of videos showing the process. That part doesn't appear to be terribly difficult or complex, though he does make things appear easy. The issue that presents the greatest challenge to me is how to secure the spindle or suitable core with the proper height and alignment to the ways.
One approach I saw, the fellow used the tailstock and the thread gears to lock the spindle in its proper location. Very good idea, however the issues here are, this headstock a. doesn't have a spindle yet, and b. doesn't have the original babbit in place to make the initial set up. Right now I'm leaning towards a bar turned to match the spindle, held in place between centers of my original headstock and tailstock. I don't like the idea of doing a pour over the bed, but I don't really see a way around it. One of the methods keith used doesn't strike me as being accurate enough for alignment to the bed. Another idea I had was to pour the bearings in go, with shims in place spanning the bearing entirely, and completely fill the area with a solid mass, then somehow mount the headstock to the carriage, or perhaps place it in the bed, and use the carrage to push it towards the headstock and bore it.
Not really sure of the most efficient way of getting it done accurately, so I'm looking for additional input and ideas. Thank you in advance.
Terry
Terry
