- Aug 2, 2024
- 19
I recently purchased a 30mm die holder for the tailstock of my lathe. I went with 30mm because my old set of hex dies are between 28 and 29mm and I figured I could shim them to get them centered. I have decided to invest in a new set of round dies that will fit in the 30mm holder. The problem I'm having is the wording I'm using as search criteria is not yielding useful results. I want to get both metric and SAE sets, but most of what I'm finding is 25mm. What kind of wording or terms do I need to put in the search box (Amazon, eBay, whatever) to get some useful results. The 30mm holder took about a month to get here (from India) and it wasn't cheap, so I really don't want to order a different one. Any suggestions or sources you can recommend?
