- Nov 16, 2012
- 5,596
Good point on the dual check valves and I'll get to that. As always I treat the gas hoses as carefully as my fingers, arms & legs. And yup, I never crack the Acy valve all the way. Did you know that freely vented Acy self ignites when it gets much past 15PSI? Also, they add about 1 gallon of naptha to a 300 size tank to stabilize it. Who ever thought something as volatile as naptha could stabilize something...
Haven't done much Acy ever since I got a plasma cutter. Used it mainly for cutting and heat treating small parts. When there was an Acy shortage a few years ago, I switched to polypropolene and found out it's only good for cutting -not heat treating. It won't produce a carburizing flame and the part gets contaminated. It cuts better than Acy though -runs at 3x the pressure -and that's why you can't weld with it either.
You may want to consider a set of flashbacks at both the torch and the regulators as I once saw a hose get burned in two when a piece of angle iron fell on it and it was rapidly burning back towards the bottles. Thank goodness someone had enough sense to turn the acetylene and oxygen bottles off quickly. Since the oxygen bottle valve is double seated I always open it wide open until it tightens, on the acetylene bottle I only open it until it registers pressure on the gauge and then just a little bit more, that way if you must shut off the bottle quickly, it is a fairly short turn.
Something else you may consider is the Koike type Quick Connectors http://www.bibowindustries.com/Gentec_KOIKE_Style_Quick_Connectors.htm , especially if you change torches frequently. These also contain a flahback built in as well as a check valve so you can remove/change the torch without shutting off the bottles.
