Ray, I checked that site out, Global......., for the $7 arresters and couldn't find them........they're $27 and up.
Just so you don't think I'm hallucinating, here they are. One's marked oxygen and the other Gas. At first, I thought they weren't rated for flammable gas but, the mfg calls them welding handle check valves. Still leery, I called the Global rep and indeed they're rated for flammable gas. And yes, before someone says something, the line in the bottom pic is Vinyl but it's only carrying 20PSI argon, Helium and CO2 -nothing flammable.
Oh I believe you. I bought mine 30+ years ago. I have seen them hanging on vacumn pack cards in the welding supplies for 25-30 buck a piece +tax. It does not surprize me a guy can buy them on the internet cheaper. Local welding supplies have gotten rediculously high.I have seen them on the regulator and the torch handle also. In my mind, like yours, the torch handle is the best place.
Paul N.
They are 2 different things:This manufacturer calls them welding handle check valves and not arrestors.
I agree with installing these, However you need to drain the lines and back the regulator T-handles "off" every time you close the bottle valves. If you open the bottle valves with the regulators set, it will often times trip the "Flash Back Arrestors". That is a good safety precaution anyway since when the bottle valve is opened with a preset regultor it can blow the regulator diaphram, pop off valve or even the case. You should also stand to the side of the regulator instead of directly in front when turn on the bottles. That is also true on Argon, 75/25 and CO2 bottles a on. MIG and TIG welders.
