I have a Lagun head with parts in a box. One of the parts is a casting that is part of the drive mechanism. The casting has 5 holes, 2 are threaded to hold it in place and 3 that have dowel pins. Two of those pins are sheered.
How can sheered dowel pins be removed?
Alternative, the pattern in the 2 mounting holes are at 180 degrees. The alignment holes are in a 120 degree pattern. I had thought about rotating the casting 180 degrees and drilling three new pin holes.
The casting is about 3 1/2 inches in diameter and the center drive hole is about 1 1/4 inch in diameter. The section that would have to be drilled is about 3/8.
Advice appreciated,
Thank you.
Dan
Advice appreciated,
Thank you.
Dan
