Hi. I’m not a trained machinist, but trying to learn as I go. I have a clamp bracket for a torque bar I am making for my Bridgeport Mill so I can use a newly acquired Tapmatic 50X tapping head. I loosely modeled my design after the stock bracket from Tapmatic’s owner’s guide. Mine, however is semi- circular to fit more snugly to the quill. I formed most of the bracket cold out of 3/8” x 1” flat bar using my Hossfeld bender. Then I drilled and tapped the clamp holes, and placed a couple of spacers in place to be able to bore the ID for a nice fit on the quill. The currant size is about 3-5/16”. I need to bore it to 3-3/8”. I haven’t had enough experience to know what would be a good speed to bore out this piece would be using a boring head on the BP. Here’s what I’m trying to to make, and what I have so far on my version. Any recommendations would be appreciated. Thanks, Jon
