- Dec 6, 2011
- 217
Astjp2,
Thank You for the supportive posts. All of you have been helpful. I like the discussion.
I see from your pictures that you also have a RD lathe. My saddle does not rock any that I can easily detect. I did take it off and clean the apron gearbox and the saddle. There was wear on the saddle surfaces but not so much. Did you happen to see the measurements I posted on the other thread (under scraping forum)? There was ,what I
feel like, very little wear. Not enough wear to cause this rather large taper effect. I most likely will get a test bar. I know that the test bar will give a spindle reference. If I use the carriage to measure against the test bar, I will get a combination error. But, that will be interesting as a starting point. I will also go to the effort of taking the head off and re-seating it based on what the test bar shows. Then I will start digging into the Connley book. I do not want to "live with" this kind of error.
My way measurements in this post thread:
http://www.hobby-machinist.com/threads/map-the-errors-on-a-older-lathe.39504/page-3
Thank You all.
Thank You all.
