- Dec 6, 2011
- 217
Continued from "Map Errors on Older Lathe".
The RD14X40 has a monster of a stiff bed. Very deep and well bolstered with large cross members.
After some careful comparison with a good precision level (Mitutoyo .0006/12") I have some twist in my
lathe bed. I have not quantified the difference at this point. I am getting a appreciable amount of taper
with the diameter increasing as the distance from the chuck increases (like .005 in 1.5 "). When i put the
level under the chuck(same place each time) and level the lathe across the bed, then move the level to the
tail end, the back side of the bed at the tailstock end is off the scale out of level high. According to good solid
information (and logic) , this can contribute to the tapering problem. After taking the twist out, I will look
at other factors such as spindle alignment (head nod , ect.).
I have "bedded" the lathe to the concrete floor. I am now making some "clamps" to hold the feet in place
when I need to pull down on a lathe foot-pad. The lathe is so stiff that if you shim up on the head-stock
backside feet, the whole back side including the tailstock end will lift. I plan to adjust this very slowly to
achieve level. When I get one completed I will post a photo and report success or failure.
