Me? Bad influence? No...
To be honest, using TouchDRO as a simple readout is only scratching the surface of what it can do. Granted, there's more to it than just the adapter and some scales, but once you go down the path of quick-change, repeatable tooling, it's hard to go back.
I recently restored an old Bridgeport for my local makerspace, and going back to reading dials, counting turns, manual edge finding, and touching off tools... Oof. Made me appreciate my own shop, and how I've set up the workflow, all the more. And it's essentially centered around TouchDRO.
If you watched my vid, you can see how quickly I can change tools in my mill. In addition to buying (and making a few) tool holders, I also made a quill lock for my mill (there's also a vid about that on my channel), specifically to improve my workflow. I also modified the spindle nose of my other mill, to work with the TTS holders. I even made a quick-change tool post for my little shaper, so I can use the TouchDRO tool library on that machine, too (vid series on that one, too).
My mini lathe has not only the usual X and Z scales, it also has a scale on the tailstock quill. This isn't terribly uncommon... But I took it a step further: I added a read head to the Z scale, attached it to the tailstock body, and summed that scale with the quill scale. This way, I never lose position when drilling a hole, even if I move the tailstock to clear chips (also a vid series on that... Sorry, not trying to plug my channel). This wouldnt be possible without TouchDRO.
