I have a BS-0 size head for my Burke Millrite with an 8x32 table, it could probably handle a BS-1 size head, and I might upgrade to that some day, but I will likely make a riser for it if I need a bigger swing rather than upgrade due to the weight difference. The PM site doesn’t list the weights, but Penn Tools shows a weight of the BS-0 size of 45lbs without chuck, and the -1 is 80lbs without chuck. I wouldn’t want to lift that on to my table and would need some sort of hoist for it since I am not getting any younger. One advantage of the BS-1, the through hole is a bit larger and might help with some projects, but it’s small enough of a difference that it is not much of a selling point unless I had a job that had to go through the spindle, or I needed larger collets to hold on to the work.
