- May 2, 2015
- 153
Yuriy
Thanks for the info!
My mount is a glass reinforced 3D printed unit - the DRO head will be connected to the quill so that it is isolated as you suggest. I verified the frame is connected to the (+) side with a multimeter - checked for continuity between the frame and the (+) contact on the battery.
New development...
Here's the shocker - contrary to what the documentation said - it doesn't use an SR44 1.5v battery. It is a 2032 3v battery.
I read your info on the Shahe vertical scales and this unit "appears" to be similar. Based on this revelation, it looks like I will NOT need a level shifter - but now I am completely confused as to the pin arrangement and connection scheme.
No idea on the clock / data / power / Gnd connections - looking at your pin out guide it appears that the Shahe units are changed drastically between models. I do not know if this in fact a Shahe system. I guess the question is how do i identify the PIN outs on the data port?
(I can use mini USB breakout board to micro USB breakout board to rearrange the connections to the Touch DRO controller)
As for why....lol, well I had the quill DRO set on the shelf. Not even sure when I bought it. I also have a penchant for doing things the hard way. (It's also fun - I think) The unit seems to be extremely well made. It has a stainless scale & housing and aluminum front panel. It uses a mini USB data port. If I recall it wasn't cheap. It came in a nice fitted wooden box as well.
Any help would be hugely appreciated.
ETA: Doing more poking around on the web, this looks virtually identical to the iGaging Vertical Quill DRO (Model #35-068)
As for why....lol, well I had the quill DRO set on the shelf. Not even sure when I bought it. I also have a penchant for doing things the hard way. (It's also fun - I think) The unit seems to be extremely well made. It has a stainless scale & housing and aluminum front panel. It uses a mini USB data port. If I recall it wasn't cheap. It came in a nice fitted wooden box as well. Pic attached
Scott
New development...
Scott
